so yeah.
The VU Meters have only “12 steps” so 12 states to be at.
Here ist the original code:
<?xml version="1.0" encoding="utf-8" ?>
Here is what i try to do
I just tried to increase that to 128, but idk if its possible to increase that so the VU meters looks more smooth
Gunnar
June 19, 2026, 9:31am
2
Hi,
Your XML code didn’t make it into the post.
Anyhow, which action are you talking about? Since you mention “12 steps”, I assume it’s about Mackie Control. These 12 steps are not a restriction made by the plugin; it’s built into the Mackie Control protocol and cannot be changed.
what if i bypass the mackie control?
My plan is to have more than those hardcoded 12 states of mackie.
But in the plugin only Mackie Controll has the option to be a VU meter
And for the VUmeter stuff i found 3 files in the plugin folder
C:\Users\”””””NAME”””””\AppData\Roaming\Elgato\StreamDeck\Plugins\se.trevligaspel.midi.sdPlugin\VUCurves
GR:
MR:
Template
Gunnar
June 19, 2026, 2:48pm
4
Those files are used by the Generic Midi dial, which, starting with version 4.3, can display VU meters.
Yeah i can display VU meters.
But only with the “Mackie Control” and nothing else
Gunnar
June 19, 2026, 4:00pm
6
For documentation, look at the last sections on the page:
For instructions, look at the video:
