Hello,
I am using the MIDI plugin with a Stream Deck XL, the loopMIDI emulator, and the RadioDJ broadcasting software.
I’ve had this setup for several months now, and everything has been working perfectly.
However, for the past two days, I’ve been having issues when trying to trigger audio jingles via RadioDJ using the MIDI plugin. The jingles start playing for a fraction of a second and then cut off immediately.
Please note that I didn’t have any issues before with this exact same setup. Currently, my other MIDI commands are working fine in the software: I can control track volumes using the dials, and I can start and stop my main playlist as well as my auxiliary players.
My issue is strictly isolated to the Instant Players used for the jingles.
Here are the logs:
2026-06-25 14:45:51.2254 44822,84ms INFO 99 Midi Logger [Logfile cleared]
2026-06-25 14:45:52.7428 1517,39ms DEBUG 99 NoteOn ReceivedSettings [b4bd2acead128048eeeec41d6281c9d1 lgn - ]
2026-06-25 14:45:52.7428 0,01ms INFO 98 Midi Logger [logging level 1 started (4.3.0.1) (create)]
2026-06-25 14:45:52.7428 0,02ms DEBUG 99 NoteOn ReceivedSettings [b4bd2acead128048eeeec41d6281c9d1 rb - ]
2026-06-25 14:45:52.7428 0,01ms DEBUG 99 NoteOn ReceivedSettings [b4bd2acead128048eeeec41d6281c9d1 Unknown property: rb - ]
2026-06-25 14:45:52.7428 0,00ms DEBUG 99 NoteOn ReceivedSettings [b4bd2acead128048eeeec41d6281c9d1 selectedCycleType - ]
2026-06-25 14:45:52.7429 0,00ms DEBUG 99 NoteOn ReceivedSettings [b4bd2acead128048eeeec41d6281c9d1 selg - Default group]
2026-06-25 14:45:52.7429 0,00ms DEBUG 99 NoteOn ReceivedSettings [b4bd2acead128048eeeec41d6281c9d1 smc - 0]
2026-06-25 14:45:52.7429 0,00ms DEBUG 99 NoteOn ReceivedSettings [b4bd2acead128048eeeec41d6281c9d1 smip - No MIDI Input]
2026-06-25 14:45:52.7429 0,00ms DEBUG 99 NoteOn ReceivedSettings [b4bd2acead128048eeeec41d6281c9d1 smop - loopMIDI Port]
2026-06-25 14:45:52.7429 0,01ms DEBUG 99 NoteOn ReceivedSettings [b4bd2acead128048eeeec41d6281c9d1 sno - same]
2026-06-25 14:45:52.7429 0,01ms DEBUG 99 NoteOn ReceivedSettings [b4bd2acead128048eeeec41d6281c9d1 snt - C3]
2026-06-25 14:45:52.7429 0,00ms DEBUG 99 NoteOn ReceivedSettings [b4bd2acead128048eeeec41d6281c9d1 tf - ]
2026-06-25 14:45:52.7431 0,18ms INFO 98 Midi Logger [logging level 1 ended (change)]
2026-06-25 14:45:52.7431 0,01ms INFO 98 Midi Logger [logging level 2 started (4.3.0.1) (change)]
2026-06-25 14:45:54.7458 2002,77ms DEBUG 95 NoteOn KeyPressed [b4bd2acead128048eeeec41d6281c9d1 Port(loopMIDI Port) Channel(0) - Key(1) - Velocity(127)]
2026-06-25 14:45:54.7459 0,11ms DEBUG 95 Connection Send_NoteOn [b4bd2acead128048eeeec41d6281c9d1 Sending Channel(0), Key(1), Velocity(127)]
2026-06-25 14:45:54.7467 0,74ms DEBUG 95 MidiController Send_NoteOn [b4bd2acead128048eeeec41d6281c9d1 message successfully sent: NoteOnMessage, InPort:No MIDI Input, OutPort:loopMIDI Port, Channel:0, Key:1, Value:127]
2026-06-25 14:45:54.7468 0,09ms DEBUG 95 StateThrottler SetState [b4bd2acead128048eeeec41d6281c9d1 same state as last, ignoring: State(False)]
2026-06-25 14:45:54.7470 0,20ms DEBUG 103 MidiController NoteOn_Received [MidiController message received: NoteOnMessage, InPort:loopMIDI Port, OutPort:, Channel:0, Key:1, Value:127]
2026-06-25 14:45:54.9457 198,72ms DEBUG 92 NoteOn KeyReleased [b4bd2acead128048eeeec41d6281c9d1 Port(loopMIDI Port) Channel(0) - Key(1) - Velocity(127)]
2026-06-25 14:45:54.9458 0,07ms DEBUG 92 StateThrottler SetState [b4bd2acead128048eeeec41d6281c9d1 same state as last, ignoring: State(False)]
2026-06-25 14:45:59.5545 4608,69ms DEBUG 99 NoteOn OnSendToPlugin [b4bd2acead128048eeeec41d6281c9d1 ViewLog : Yes]
I think the issue started after the 4.3 update.
Thx
T-O
