Dorico beta 1.0.0.296
This version should better handle backslashes and “ in Dorico commands.
Please note that this is a breaking change if you have manually added \\ and \” to make the previous version work. Now, commands should be used exactly as they are read from the Dorico log file.
Version 1.0.0.296
Thank you so much, Gunnar! The commands I’ve tested so far work with the update. I’ll continue testing.
