I wanted to share a function to manage single Press, Double press and Long Press in javascript.
1/ Place this code in file named PressHandler.js (after replacing xxx with your user name) in your js directory :
/// <reference path="C:/Users/xxx/AppData/Roaming/Elgato/StreamDeck/Plugins/se.trevligaspel.midi.sdPlugin/ScriptJint/streamdeck-midi.d.ts" />
const tSuffix = "_pt";
const LONG_PRESS_MS = 400;
// Internal state for the single button
let clickCount = 0;
let isPressed = false;
let longFired = false;
// Callback references
let singlePressFn = null;
let doublePressFn = null;
let longPressFn = null;
// Store the last registered button name
let buttonNameGlobal = "";
* Register the single button
* Returns the _pt timer name
function registerButton(buttonName, singlePress, doublePress, longPress) {
buttonNameGlobal = buttonName;
singlePressFn = singlePress;
doublePressFn = doublePress;
longPressFn = longPress;
// ✅ return the press timer name
return buttonName + tSuffix;
* Handle press/release events
function ButtonHandler(event) {
if (!buttonNameGlobal) return;
const tname = buttonNameGlobal + tSuffix;
if (event === "press") {
isPressed = true;
if (clickCount === 0) {
longFired = false;
timer.reset(tname);
timer.restart(tname, LONG_PRESS_MS);
else if (event === "release") {
isPressed = false;
if (!longFired) clickCount++;
* Timer callback
function handleTimerElapsed(tname, isGlobal, time) {
if (tname !== buttonNameGlobal + tSuffix) return;
const count = clickCount;
clickCount = 0; // reset first
if (isPressed && longPressFn) {
longPressFn();
longFired = true;
else if (count === 1 && singlePressFn) {
singlePressFn();
else if (count >= 2 && doublePressFn) {
doublePressFn();
timer.reset(tname);
module.exports = {registerButton, ButtonHandler, handleTimerElapsed};
Then create a scripted button and use this template (after replacing xxx with your user name).
Customize singlePress(), doublePress() and longPress() functions to your liking:
/// <reference path="C:/Users/xxx/AppData/Roaming/Elgato/StreamDeck/Pluginsse.trevligaspel.midi.sdPlugin/ScriptJint/streamdeck-midi.d.ts" />
const{registerButton, ButtonHandler, handleTimerElapsed} = require("./PressHandler.js");
const bName = "PressTest";
const bName_dt = bName + "_dt";
const DISP_MS = 1500;
let longActive = false;
ui.text("Start");
function OnInit() {ui.text("Init")}
// Register button
const bName_pt = registerButton(bName, singlePress, doublePress, longPress);
// Callbacks for single Press, Double Press or Long Press
function singlePress() { ui.text("Single Press"); timer.restart(bName_dt, DISP_MS);}
function doublePress() { ui.text("Double Press"); timer.restart(bName_dt, DISP_MS);}
function longPress() {
ui.text("Long Press");
longActive = true; // mark long press active
// Stream Deck events
function OnKeyPressed() {ButtonHandler("press");}
function OnKeyReleased() {
ButtonHandler("release");
if (longActive) {
longActive = false;
//timer.reset(bName_dt);
function OnTimerElapsed(tname, isGlobal, time) {
switch(tname) {
case bName_pt: handleTimerElapsed(tname, isGlobal, time); break;
case bName_dt: {
ui.text("Idle");
break;
default: return;
et voilà !
I have tested it but use at your own risk.
