Migrating scripts to Javascript
Just for reference, here is the Javascript page.
I would happily migrate all my scripts to Js, if it was not for the time it’s going to take. :face_without_mouth:
I’ll also probably have a bunch of questions, among which :
  • How to share global variables across Js and legacy scripts ?
    (I read it’s possible in the old forum)
  • Also regarding this code (to be placed in a “jsconfig.json” file, which version (target) can we use ? :
  "compilerOptions": {
    "target": "ES2016",
    "module": "commonjs"
  "exclude": ["node_modules"]
  • can we have common modules like “mySharedFunctions.js” with module.exports = {f1, f2};
    and then const{f1, f2} = require(“./mySharedFunctions.js”); referenced in other modules.
… and also,
  • can I put js files in a different directory than legacy scripts?
  • do we have some logging capabilty, like with post() ?
Those are good questions.
  • The idea of creating a migration tool for scripts has crossed my mind, but without thinking it through, I deemed it too complex, and I have way too many other things to do that I find more important.
  • It’s the same variable controller for global variables in both the old and new script engines, so as long as the variables are named the same (without the @ prefix), they will work across all scripts.
  • The GitHub page for the JavaScript engine has a long list of what it supports.
    GitHub - sebastienros/jint: Javascript Interpreter for .NET · GitHub
  • Exports and references to shared resources are currently not supported. These features are incompatible with how the JavaScript engine is integrated with the plugin. I recognize the potential benefits of having these features, but I haven’t had time to explore possible solutions.
  • Each script reference is independent, so you can place scripts anywhere you like.
  • I have considered logging, but unfortunately, it is not available yet. Where do you want log entries to be written: in the plugin log file or elsewhere?
Hello,
In response to your answers …
  • migration tool for scripts. Maybe an IA fed with the scripting language documentation would help, don’t you think ?
  • global variables. The point is getting notified in js when they change, as in the old scripts. any idea ?
  • Exports and references to shared resources. I understand it is now available. Correct ?
And to be a bit provocative :melting_face: …
why not getting rid of c# ?
migration tool for scripts. Maybe an IA fed with the scripting language documentation would help would help, don’t you think ?
Cool suggestion, I didn’t think of that. :slightly_smiling_face:
That’s what the OnGlobalVariableChanged(name, value) event is used for.
Correct.
I didn’t understand that. Where would I be getting rid of C#? If you’re suggesting that I should spend time converting 6 years of C# development to JavaScript, I think I’ll pass. :wink:
I too was confused by this comment. I taught myself coding from the age of 13 (I’m now 60) and I found C# to be an easy language to get to grips with and I like the architecture behind it. I’ve developed many apps and services using a mixture of Delphi/C/C++/C#/Java and had to get to grips with understanding and fixing apps written in VB.NET. I found C# a good language. Why change what isn’t broken and works well, is still a very valid statement :zany_face:
