Scripted Button Refresh Images
I’ve created my first midi scripts to implement some cycle buttons and they are working (!).
I’m Loading From File, however, and am struggling when making tweaks to get into to load the changes correctly. It seems the file gets stored in memory and won’t import a new one of the same name.
The only work-around that I’ve found is to rename the files (midi script and image files).
I’ve tried power cycling the Stream Deck, deleting the button, etc, but it keeps returning to the original files.
Is there a way to flush the memory and reload? If not, that would be my feature request.
Thanks!
You are correct that images are cached in memory. The only way to clear the cache is to quit the Stream Deck software and restart it.
I’ll note this as a feature request.
The latest beta version has a button to clear the image cache.
Thanks, Gunnar, I’m running it now and see that option. I swear I pulled the plug on my SD+ yesterday and that did not solve it. Maybe the Stream Deck GUI holds it? No matter, should not be an issue now with the new feature.
