V-Pot design Issue
Hi @trevligaspel , I’m having an issue with the generic midi button with the V-Pot type as it doesn’t recognise my own V-Pot design, it seems to be something related either with the last update of stream deck or the plugin itself as I’ve never had this problem before.
Stream deck : 7.3.1 (22604)
MIDI plugin: 4.2.0.4
Thank you very much for your incredible work with this plugin!!
Hi,
Please perform the procedure described in the last section of the FAQ page. Please note that the step “Upload the log file” means pressing the “Upload log” button; do not attach the log file to a forum post.
Hi Gunnar , thanks for the reply, I just uploaded de log file , do you need the ID?
Yes, please. Otherwise, I can’t find it among the other uploaded logs.
Hi Gunnar:
Forget about it , I managed to solve the issue thanks to the log , I was missing the DialKnobBackground.png on each folder of the knobs.
A little bit weird as I mentioned it used to work fine, anyway problem solved!!
Thanks again for your help
